battery light stays on
255,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
JOE1953
  • 809 POSTS
when I start the engine the battery light stays on. I installed a new alternator and the battery light is still on. I check the battery with the engine off it is 13 volts and I check the charging volts while the engine is running it is 13.9 volts. why is the battery light staying on? what else can I check and how do I fix the problem?
Nov 2, 2016 at 12:23 PM
HMAC300
  • 48,601 POSTS
check fuses in picture under hood and in car.
Mar 17, 2021 at 4:27 AM
JOE1953
  • 809 POSTS
where is the main fusible (12 gauge) located?
AL514
  • 5,692 POSTS
That fusible link should be located somewhere close to the battery coming right off the positive lead. Fusible links are a bigger fatter part of the wire usually black in color and they are also usually grouped together with a couple other ones as well. Another place it may be is in the fuse panel under the hood (engine compartment fuse box). They will usually be rapped in black heat shrink like picture 2 here.
JOE1953
  • 809 POSTS
i didn't find any fuses blown or a Fusible links near the battery and in the fuse box so I looked at the connector it was bad so I got a new one fixed it.
JOE1953
  • 809 POSTS
I didn't find any fuses blown or a Fusible links near the battry and in the fuse box so a fuse or a Fusible links will cause the battry light to stay on?
