Engine shut off while idling due to a drained battery, now it will not crank
250,000 MILES • 0.5L • V8 • 2WD • AUTOMATIC
TRACY JOY
Truck was idling in park for about 5 to 10 minutes the engine shut off and all battery power was gone causing the battery terminal to fry. I replaced the battery with a new one. Now the truck won't turn over.
Mar 31, 2021 at 2:18 PM
  • 110,248 POSTS
A drained battery won't cause the terminal to fry. It sounds like something was drawing too much power. Is it possible for you to take a few pics of the cable you are referring to and upload it for me to see?
Since the starter won't engage, I need you to start by checking mega fuse 6 in the under hood power box. See pic 3 below.
Also, pics 1 and 2 show the entire wiring schematic for the starting system. You can use this as a reference.
When checking the fuse, confirm there is both power to it and from it. Here is a link you may find helpful:
IF the fuse is good and there is power to and from it, we need to check for power at the starter. Here is a link that explains how that is done.
If possible, please upload a pic of the battery terminal in question. If something was drawing enough power to fry it, we may have a bigger issue.
Apr 1, 2021 at 12:56 PM
