Battery voltage gauge drops?
178,321 MILES • 4.7L • V8 • 4WD • AUTOMATIC
JEANNPO
  • 8 POSTS
When I started my vehicle today and was about to turn out of my complex, my check gauges light came on and I noticed that my battery voltage gauge was at zero. I turned back around and came home and turned off the vehicle. I sat for a couple of minutes, then started the vehicle again. This time, watching my gauges. It was normal for a few seconds, then dropped back down. I turned off my vehicle. Later, I went and looked at my battery, and I noticed corrosion. I bought a brand-new battery, put it into my vehicle, started it back up and it happened again. My vehicle was running just fine the other day.
Nov 16, 2022 at 10:03 AM
  • 110,251 POSTS
It sounds like either the alternator is failing, there is an error with the gauge, or the PCM is failing.
Here is what I recommend. Let's check something at home. All you will need is a voltmeter or multimeter. Follow the directions in this link and let me know the results.
I'm questioning the gauge because even if the alternator isn't charging, the gauge should still indicate battery voltage and not 0. Do this and let me know.
Let me know what you find.
Nov 16, 2022 at 1:14 PM
JEANNPO
  • 8 POSTS
Thank you for responding, and your suggestion. I will try it tomorrow and let you know.
Nov 16, 2022 at 4:37 PM
JEANNPO
  • 8 POSTS
Okay, so instead of using my multimeter to test my vehicle (too much risk of not doing it correctly), I took it to AutoZone and had them run the free fix it test. The only thing that came up was with the power train system, a p0161: 02 heater circuit (bank 2, sensor 2). I have already ordered the part and I pick it up Saturday afternoon. He told me that it was ok to drive my vehicle until then. Is that true? Also, how difficult is it to replace? I am somewhat mechanically inclined….. I took out and replaced my alternator myself with a bar to break the bolts loose that I came up with on my own, using the butt end of my jack crank handle and a socket wrench that I put inside of the end that I reinforced the strength with electrical tape where I put them together and a hammer. Oh, and I did pay attention to my battery voltage gauge more closely, and it only dives down to 8, not below the red line which would be at zero.
Nov 17, 2022 at 8:25 AM
  • 110,251 POSTS
The codes he found are for the oxygen sensors and have nothing to do with the charging system. In this case, if the voltage is going to 8v, the alternator is not charging at that point.
The battery is 12v. Usually, you will see that voltage or near that voltage when the engine is off. When the engine is running, checking the voltage of the battery should be around 14v. If you are seeing 8, then we have a problem.
In most cases, it isn't a wiring issue, but instead, it is the alternator or voltage regulator that is failing. On this vehicle, the voltage regulator is integral to the powertrain control module. As a result, my first suspect of failure is the powertrain control module. That is based on the same thing happening with the new alternator as did with the original one.
Let me know your thoughts and if you have questions.
Nov 17, 2022 at 8:57 AM
JEANNPO
  • 8 POSTS
Can I drive my vehicle in the meantime? My job is 15 miles, there and back. I’ll be fixing my vehicle next week.
Nov 21, 2022 at 7:19 AM
JEANNPO
  • 8 POSTS
I’m waiting for the new alternator.
Nov 21, 2022 at 7:21 AM
  • 110,251 POSTS
If the battery fails while driving, it will shut the vehicle off. That is a tough question to answer for you. I say that because if the battery isn't fully charged and you use any of the electronics, it will cause the battery to fail faster.
Will you hurt the vehicle? I don't feel it would. My concern is that you won't make your destination.
PS: Also, before making the purchase for a new alt, remove your old one and have it bench-tested at the parts store. They will do it free of charge. I suggest this because the issue can be the alternator, a wiring issue, or the powertrain control module.
Nov 21, 2022 at 11:33 AM
JEANNPO
  • 8 POSTS
Okay, this is where I am at now. I bought a new battery, bought a new alternator and a serpentine belt. All of which I put in my vehicle. At first, it seemed as if everything was ok. However, the next day, when I went to test it out, I did wait a few before I went to leave with the engine running. Then when I backed out of my parking stall, and put it into drive, I heard a chime, looked at my dash, and my check gauges light came on, and once again, my battery voltage took a dive, just as it did previously! I immediately parked my vehicle back into my carport and shut it off!!! Also, when I changed my alternator prior to this, I noticed that the 2-pin electrical wire that plugs into my alternator had been fried, so I replaced it too!!! I have absolutely no idea where to go from here!!!
Dec 25, 2022 at 12:30 AM
  • 110,251 POSTS
If the alternator isn't charging, the PCM is the likely problem. On most vehicles, the voltage regulator that controls the alternator is integral. On this vehicle, the voltage is regulated by the powertrain control module (PCM).
I mentioned above that either it would be the alternator or the PCM. If you want to confirm that, remove the alternator and have it bench-tested by the parts store. If it is good, the PCM is the likely cause.
So, we have two ways you can repair this. First, you can have a shop or dealer sell you a new PCM and then charge you to program it to your vehicle. That will be somewhat expensive to have done. Or you can purchase a remanufactured PCM online that is plug-and-play. They will need your VIN number and when you install the new PCM, you will need to send back the old one. As I mentioned, I've gone this way and have been very happy with the results. Simply, disconnect the negative battery terminal, remove and install the new PCM and it's done. Just make sure you are getting one that is already programmed.
I have done this on my personal vehicles simply due to the cost. The last one I did was on a Dakota and the remanufactured part was 129.00. I know that's a lot, but to go the other way would likely be close to 1000.00.
If you look at the pics below, it shows the location and removal procedure for the PCM. The very last pic shows the parts and labor if you go with a new one.
Let me know your thoughts. Also, when I read back through the thread, I noticed that when I indicated it could be the alt or PCM, you took it to a parts store, and they scanned the computer. They needed to test the charging system. That's why you were unaware.
Let me know what you decide and what I can do to help.
Dec 25, 2022 at 10:44 AM
JEANNPO
  • 8 POSTS
I literally just put the new alternator in. How would it not be good already???
Dec 25, 2022 at 3:48 PM
CARADIODOC
  • 34,416 POSTS
You aren't bothering to read Joe's replies or you would have had this solved already. It is not the alternator, so why are you still looking at it? A few simple voltage tests on that two-wire plug would have shown which direction to start the diagnosis rather than wasting money on unneeded parts.
The charging system that keeps the battery charged is made up of a half dozen parts with wires and connectors between them. Any one of those parts can cause this problem. You tried one of them already. Now it's time to figure out which one of the other parts is at fault.
I want to know the solution. Please don't keep me in suspense.
Dec 26, 2022 at 6:38 AM
