battery test
150,000 MILES • 0.8L • 4 CYL • FWD • MANUAL
KHALIDDVD
  • 56 POSTS
how to test battery with electronic battery tester if the CCA is not labeled in battery specification .
Sep 29, 2016 at 10:51 PM
HMAC300
  • 48,601 POSTS
if you have a battery tester put a load on it of 250 amps if it has an adjustable rheostat then watch voltage if it goes down to 9 volts you need a new battery.
Sep 29, 2016 at 11:47 PM
WRENCHTECH
  • 20,760 POSTS
It sounds like you are using a conductance tester. The CCA input is just used to create a pass or fail point. You will still get an accurate CCA reading from the test no matter what number you put in there. I usually just guess at the number. You can also use a battery application catalog and that will tell you what the required CC is for that vehicle. Yours should be around 500 to 550 CCA.
Sep 30, 2016 at 3:54 AM
