How to stop battery terminal corrosion?
81,000 MILES • 4 CYL • 4WD • AUTOMATIC
DIDI7154
  • 30 POSTS
Hello, my battery, 4 years old, keeps getting corrosion and foam around the terminals and the battery itself. I’ve charged it and added distilled water to the battery, and it is functioning fine. I’ve cleaned the terminals a few times, but the corrosion keeps coming back. What is causing the corrosion and how can I get it to stop?
May 9, 2022 at 1:25 AM
STEVE W.
  • 15,415 POSTS
Check the alternators charging voltage. If it charges at a higher voltage, it is likely the cause of the problem.
May 9, 2022 at 2:44 AM
