it smelled like an electrical fire, near the starter
138,000 MILES • 4 CYL • 2WD • AUTOMATIC
MICHAEL WRIGHT2
  • 10 POSTS
Hello, my positive battery terminal screw some how got stripped and the wires moved on my car. I pulled over and there was smoke and it smelled like an electrical fire, near the starter. I looked and the negative wire that goes to the starter was fried. The car wouldn't start anymore, in fact no electricity at all came on. does anyone have an idea of what might need to be done to fix this issue?
Sep 6, 2019 at 9:05 AM
Good evening
The first thing I would do is replace the battery cables.
Is the battery damaged?
Sep 6, 2019 at 11:09 AM
MICHAEL WRIGHT2
  • 10 POSTS
I don't believe so, the battery is only two years old but the screw on the positive terminal somehow got warped and the wires ground wires began to move. This made the car turn on and out and the, I believe negative cable to the starter melted or the plastic around it. The car has no electricity anymore at all.
Sep 6, 2019 at 11:24 AM
Okay, start with replacing the cables. You can get them at a parts store.
REMOVAL
1. Turn the ignition switch to the Off position. Be certain that all electrical accessories are turned off.
2. Disconnect and isolate the remote battery negative cable terminal.
3. Remove the battery from the vehicle.
4. One at a time, trace the battery cable retaining pushpins, fasteners and routing clips until the cables are free from the vehicle.
5. Remove the battery cables from the engine compartment.
INSTALLATION
1. Position the battery cables in the engine compartment.
2. One at a time, install the battery cable retaining pushpins, fasteners and routing clips until the cables are installed exactly where they were in the vehicle.
3. Install the battery in the vehicle.
4. Connect the remote battery negative cable terminal.
Sep 6, 2019 at 11:30 AM
MICHAEL WRIGHT2
  • 10 POSTS
So the cable that run to the starter can be replaced? I can do the job I just didn't know if those cables that run to the starter could be replaced? I did see some connections. I'm a novice when it comes to working on cars.
Sep 6, 2019 at 11:36 AM
Yes, they can be replaced individually.
Sep 6, 2019 at 11:38 AM
MICHAEL WRIGHT2
  • 10 POSTS
Thank you so much. seems like an easy fix I will get on it tomorrow.
Sep 6, 2019 at 11:41 AM
You are welcome.
Always glad to help.
Sep 6, 2019 at 11:44 AM
