Battery replacement issues?
125,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
HENRY MARTIN
The battery drained in the car. I jump started it but after I jump started it when I pressed on the gas it would not move the car. The transmission was working fine before the battery drained.
May 11, 2025 at 12:14 PM
  • 55,694 POSTS
Does the engine rev up when you press the accelerator? If so, I would do a hard reboot of the computer system.
This guide can show you how that is done which takes about 10 minutes:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
This will reset the system and give it a chance to recompile the operating system. Let me know how it goes.
May 12, 2025 at 4:56 AM
HENRY MARTIN
Ken L Thank you for your response the car does not rev.
May 13, 2025 at 1:11 AM
  • 55,694 POSTS
Yes, did you try the hard reboot?
May 14, 2025 at 3:30 AM
HENRY MARTIN
Yes I have.
May 15, 2025 at 3:38 AM
  • 55,694 POSTS
Lets check the transmission fluid and run the codes, also please check the fuses, sometimes you may have a voltage spike which can pop a fuse, here are three guides to go over to help us see what is going on:
and
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
and
Please check the fuses with the systems (ignition) on. Please go over these guides and get back to us.
May 15, 2025 at 5:04 AM
