coolant light keeps coming on
150,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
PAMELA GUNTER
green line twelve volt battery replacement.
Also, the coolant light keeps coming on. I have checked for leaks, coolant level and if the fan is running. No problems visible.
Jun 26, 2017 at 3:38 AM
  • 55,721 POSTS
It sounds like the coolant level sensor in the reservoir is bad and needs to be replaced, You replace the entire reservoir in the is case, here is a guide that will give you an idea on what you are in for when changing it out.
https://www.2carpros.com/articles/coolant-reservoir-replacement
Cheers, Ken
Jun 28, 2017 at 10:43 AM
