Battery replacement?
220,000 MILES • AUTOMATIC
DAVID CHANDLER FARR
  • 41 POSTS
I have a 2010 Nissan Altima 2.5s and the battery I have for it is everstart max
Group size 35
640 CCA
My question is I have a similar battery which is a
everstart plus
Group size 35
525 CCA
Can I use the similar battery with same group size but a little less cold cranking amps?
Jun 20, 2024 at 7:33 PM
  • 55,711 POSTS
Yep, it should not be a problem, here is how to change the battery correctly. Here is a generic guide to help you step by step with instructions in the diagrams below to show you how to use your car:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Check out the images (below). Let us know if you need anything else.
Jun 21, 2024 at 3:35 AM
