Battery replacement
2010 CADILLAC CTS
140,000 MILES • 3.6L • 6 CYL • AWD • AUTOMATIC
T-BONE16
  • 6 POSTS
While trying to replace the battery I discovered that the positive cable has a different connection to the battery than the negative cable. How do you disconnect this?
Dec 28, 2016 at 8:25 AM
CARADIODOC
  • 34,380 POSTS
Can you describe what you are referring to? Do you mean a different tool is needed? If your battery has top posts and you're finding they are different sizes, the positive post is always larger in diameter than the negative post. Be careful to not connect the cables backward as that has the high potential to destroy a lot of computers.
Dec 28, 2016 at 9:02 AM
T-BONE16
  • 6 POSTS
There are three wires on the connector which does not secure to the post like the negative.
Dec 29, 2016 at 5:25 AM
CARADIODOC
  • 34,380 POSTS
Those wires are bolted to the clamp which is bolted to the post. Do not remove the nut holding the three wires. Just unbolt the clamp like you did on the other post.
Dec 29, 2016 at 7:02 AM
T-BONE16
  • 6 POSTS
The clamp does not have a bolt/nut. It has what looks like a handle that might lift up to swing around.
Dec 29, 2016 at 8:02 AM
CARADIODOC
  • 34,380 POSTS
Hmm. Any chance you could post a photo of it?
Dec 29, 2016 at 8:13 AM
