battery removal
51,000 MILES
DIM
hard to get at the battery to lift it out. which is the easiest way and best for the car.
there is an arm above the car that seams to be a frame stablizer or the fuse box which looks touchy
Apr 13, 2013 at 2:17 AM
remove the strut rod. 3 13mm bolts
unbolt the fuse box and move it up a little
undo the cables and hold down. then the battery has to turn 90 degrees to come up
roy
Apr 13, 2013 at 2:33 AM
DIM
the metal bracket is above the car "battery" sorry and the fuse box is on the side. The battery is in a tight spot.
Apr 13, 2013 at 2:34 AM
DIM
DiM
Apr 13, 2013 at 3:31 AM
