battery not charging warning message on even though alternator is charging successfully
40,000 MILES • AUTOMATIC
ALLSORTSMG
I'm trying to establish why I have the error message telling me the battery is not charging when it is working fine otherwise. 14.2v at battery when running, 12.6v when not running
Alternator is l3b-he type. ignition in, battery out plus warning light wire out..... what signal should be present on this warning light output, please?
any other clues?
Thanks,
Mick
Mar 12, 2014 at 5:34 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
that info isn't available to me, but id have to assume that battery voltage would come out of that wire and id check for plug damage and continuity in that wire first. its the gray/white one
Mar 12, 2014 at 10:01 AM
ALLSORTSMG
Thanks. Any idea where the slate/white wire goes to, is it to a relay or the ecu etc?
Mar 12, 2014 at 11:01 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
the diagram showed it going right to the charge warning light. seemed strange to me but jaguar does things differently
Mar 13, 2014 at 8:59 AM
ALLSORTSMG
Thanks. have proved it's the new alternator not producing the 12v output on the lamp circuit. A 12v singnal on that wire (after disconnecting from alternator) cures it.
Mar 14, 2014 at 4:33 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
glad you've found it and youre welcome
Mar 14, 2014 at 7:39 AM
