Battery not charging?
78,000 MILES • 8.2L • V8 • 2WD • AUTOMATIC
MR DON'T KNOW
  • 6 POSTS
Bought a new alternator multimeter reads 15 volts and when I attached cable to battery it reads 12.36 volts and won't go much higher when throttle is given. I checked the wiring on the ignition switch and all is fine.
Jun 6, 2019 at 5:34 AM
Good afternoon,
When did it read 15 volts?
Was the engine running when it read 12.36 volts?
Jun 6, 2019 at 5:48 AM
MR DON'T KNOW
  • 6 POSTS
Read 15 volts when I started it. checked the voltage from alternator then attached cable to battery and volts read 12.36 and wouldn't go much higher after I pressed on the throttle.
Jun 6, 2019 at 5:58 AM
15 Volts? Did you run the engine with a battery cable disconnected?
Jun 6, 2019 at 6:05 AM
MR DON'T KNOW
  • 6 POSTS
I had the cable that connects to the alternator disconnected to see if was producing volts. Once it read 1.5 to 1.76 then it started to read 15 volts that's when I attached cable to battery.
Jun 6, 2019 at 6:08 AM
Okay, thanks.
No, it will not charge if the cable is off. The alternator needs battery voltage to charge the magnets for it to work.
You removing it and installing it while running most likely failed the alternator.
Never ever do that. Voltage spikes are never good for the system.
Jun 6, 2019 at 6:11 AM
MR DON'T KNOW
  • 6 POSTS
Alternator still reads 15 volts but when I attached cable and start engine battery reads 12.36 volts. Can it be a ground problem?
Jun 6, 2019 at 6:14 AM
No, it is not charging if it is reading 12.36 volts. That is the battery voltage.
Jun 6, 2019 at 6:25 AM
MR DON'T KNOW
  • 6 POSTS
Then why does the alternator read voltage before it is attached to battery but not charging it after it is attached?
Jun 6, 2019 at 6:28 AM
That is an internal issue. Again, you should never remove and attach the cable with the engine running. You failed the regulator and the diode trio.
Jun 6, 2019 at 6:32 AM
MR DON'T KNOW
  • 6 POSTS
Okay, thanks. I replaced the alternator and it is all fixed.
Jun 6, 2019 at 6:35 AM
You are welcome.
Always glad to help.
Jun 6, 2019 at 6:38 AM
