battery not charging
286,000 MILES
AUGMAN3
  • 8 POSTS
I have a '99 honda civic lx that the alternator and battery went out it is a manual transmission. I repalced them and now the battery will not charge. I replaced the alternator a second time due the new alternator failed the bench test. The latest alternator passed the bench and the car still does not charge. It runs fine but if I use heat/ AC or radio the car will not restart due to dead battery. As a side the vehical speed sensor stoped working at the same time which I have replaced twice and it still does not work. I thought it was a bad alternator connector so I went to a junk yard found a honda with and replaced about 1 foot of wiring harness but still does not charge? Any tips or thoughs?
May 20, 2013 at 11:35 AM
SATURNTECH9
  • 30,868 POSTS
Do you have a multi meter? Were going to have to do some testing.Also what size engine do you have?
May 20, 2013 at 11:45 AM
AUGMAN3
  • 8 POSTS
Yes I have a multi meter
Engine is 1.6L sohc 4-cyl 16 valve engine w/5 speed manual transmission
May 20, 2013 at 11:52 AM
SATURNTECH9
  • 30,868 POSTS
Alright with the key in the run position see if the white wire and the black wire with a yellow stripe at the alternator has battery voltage?
May 20, 2013 at 12:08 PM
AUGMAN3
  • 8 POSTS
The key was in position 2 which turned on the accessories but was not started.
First check battery voltage good
Next check white wire to ground = 0
then white wire to black/yellow strip =0
back/yellow strip to ground = 0
Did not get battery voltage.
May 22, 2013 at 4:04 AM
SATURNTECH9
  • 30,868 POSTS
For the white wire check the 80 amp fuse which is number 41 in the under hood fuse box.Next for the black and yellow wire check the 7.5 amp fuse number 15 in the under dash fuse box.Let me know what you find.
May 22, 2013 at 2:56 PM
AUGMAN3
  • 8 POSTS
It is fixed! Thanks when I check the fuse the first time I must have pulled the wrong fuse. I am very greatful for the help!
May 23, 2013 at 2:11 AM
SATURNTECH9
  • 30,868 POSTS
Your welcome glad to hear you found the problem I had a feeling you had a blown fuse from the bad alternator.
May 23, 2013 at 5:26 AM
AUGMAN3
  • 8 POSTS
Reaching out for any help I can get. So I replaced the fuse it works well for about 7 days and now has stopped charging and keeps blowing fuses every time I start (that same spot as was blown prior). Any suggestions?
Thanks
Jun 1, 2013 at 11:44 AM
SATURNTECH9
  • 30,868 POSTS
Have you checked the wire for short to ground yet?
Jun 1, 2013 at 12:30 PM
AUGMAN3
  • 8 POSTS
Yep tried that. Do you know if the oxygen sensor is on that same fuse as the alternator for a 1999 Honda civic? Still trying to find the problem.
Jun 30, 2013 at 8:59 AM
SATURNTECH9
  • 30,868 POSTS
Which exact fuse is blowing?
Jun 30, 2013 at 10:53 AM
AUGMAN3
  • 8 POSTS
Jun 30, 2013 at 2:08 PM
AUGMAN3
  • 8 POSTS
which is labeled alternator and vehicle speed sensor but I am wording if it is in the same circuit as the oxygen sensor because that is the computer code that is coming up.
Jun 30, 2013 at 2:11 PM
SATURNTECH9
  • 30,868 POSTS
sorry for the long delay I didn't get a email alert you responded I just saw your reply I posted what that fuse powers doesn't power the o2 sensor.
Jul 2, 2013 at 1:46 PM
