Battery not charging?
205,000 MILES • 4.0L • MANUAL
TAYLON
Just recently pulled the motor and transmission got it all out back together now the battery won’t charger I’ve replaced the alternator and battery what could cause it to not charge it’s getting power to the alternator but it not putting any out to charge the battery
Aug 26, 2026 at 5:30 AM
  • 55,758 POSTS
Okay, first make sure there is power at the large lug at the alternator first. Also, check the 15 amp alternator fuse in the engine bay fuse panel. Here is a guide to help with the testing and the alternator wiring diagram so you can check the wiring and see how the system works.
https://2carpros.com/articles/how-to-check-a-car-alternator/
Let me know what you find.
Aug 26, 2026 at 9:59 AM
TAYLON
It is get 12 volts to the alternator just not putting any charge out and I’ve checked all the fuses none are blown
Aug 26, 2026 at 10:04 AM
CARADIODOC
  • 34,415 POSTS
Hi Taylon. I'm following along to learn the solution. To help Strailer help you, please be specific when you list your measurements. In this case, there needs to be 12 volts in three places. One is the large, bolted-on, black / orange wire Strailer mentioned. If that's missing, the best suspect is a burned fuse link wire. That's a short section spliced into the fatter black / orange wire. Tug gently on it to test it. If it acts like a wire, it's okay. If it's burned open, it will act like a rubber band.
You must also have 12 volts all the time on the yellow wire in the three-wire connector. No need to unplug that connector to make this test. Just touch the probe of your meter or test light on the back of the terminal where the wire goes into the connector body. If that's missing, check the 15-amp fuse.
The green / red wire is a little confusing. You'll need to test this one at first with a voltmeter, not a test light. With the ignition switch on, engine off, you should find close to 2 volts. The rest of the 12 volts is dropped across the "Battery" light on the dash, and that light will be lit up. This is the "turn-on" circuit that tells the built-in voltage regulator to start running the generator. Once it begins generating output current, a sample comes out on the white wire, then the regulator puts 12 volts out onto the green / red wire to turn the dash light off, so that's the third place to find 12 volts.
This is normally a pretty easy system to diagnose, so I'll go sit in the corner and wait to learn what happened. Holler if you guys need my wondrous wisdom.
Aug 26, 2026 at 3:21 PM
TAYLON
So I did some testing not sure I did it right never really used a multimeter before but on the black and orange wire I’m only getting .02 with the truck running and. Nothing on any of the wires in the connector
Aug 27, 2026 at 7:06 PM
  • 55,758 POSTS
Yep, it looks like the fusible link "B" is bad. You should have 12 volts to the blk/orange wire all the time.
Aug 29, 2026 at 7:51 AM
