Now I am getting 14.7 volts when I check between solenoid mounted on fender and negative post on battery. Across negative post and positive post on battery is 11.2. Should it make a difference on which stud on solenoid I check. One side of solenoid is 14.7 other side is 11.2.
May 30, 2016 at 11:22 AM
