Battery not being charged
330,000 MILES • 4.9L • 6 CYL • 2WD • MANUAL
WILLIE BURKETT
  • 14 POSTS
The alternator in the picture is the correct one.
May 30, 2016 at 12:52 AM
SATURNTECH9
  • 30,868 POSTS
The alternative in the picture is the correct one? did you post is picture? I do not see one? also the one that was replaced you had tested and it tested bad?
May 30, 2016 at 1:37 AM
SATURNTECH9
  • 30,868 POSTS
Also do you have a internal or external voltage regulator?
May 30, 2016 at 1:43 AM
WILLIE BURKETT
  • 14 POSTS
Internal.
May 30, 2016 at 1:44 AM
WILLIE BURKETT
  • 14 POSTS
The picture was from another reply.
May 30, 2016 at 1:47 AM
SATURNTECH9
  • 30,868 POSTS
Use a voltmeter and put the negative lead to the case of the alternator and the positive lead to the terminal a at the back of the alternator you should have battery voltage?
May 30, 2016 at 1:59 AM
