Battery message on i drive display
175,000 MILES • V8 • TURBO • 2WD • AUTOMATIC
NASER NASER
  • 836 POSTS
Keep getting this message randomly, car starts every time with no issues.
Feb 29, 2020 at 10:22 AM
  • 110,248 POSTS
The vehicle has an intelligent battery sensor that records all kinds of information. From the battery's stability, temperature, voltage dip on last start up (which is used to calculate the battery's age based on change) and so on, the battery is constantly being watched.
If you are seeing the light, the battery may be getting old and the system is picking up weakness or change. Don't be over concerned at this point, but if you start noticing a slower start or the light coming on all the time, replace the battery.
Also, make sure to purchase a new battery that meets all the vehicle's needs.
Take care and have a good weekend.
Feb 29, 2020 at 10:44 AM
NASER NASER
  • 836 POSTS
Can I disconnect the wire at the battery for the ibs?
Feb 29, 2020 at 8:34 PM
  • 110,248 POSTS
Negative. It sends and receives multiple signals. I feel confident that will cause more issues and will turn the light on all the time.
Mar 1, 2020 at 10:16 AM
