battery light stays on with engine turned off.
2006 GMC YUKON
169,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
HARLEYGUY13126
battery went dead after jumping the vehicle and running for extended period of time I shut engine off and noticed that the battery light was on. when engine is running the battery light is out.Replaced the battery and the same thing happens.What causes this light to stay on when the engine isn't even running. Thank you for your help.
Oct 14, 2015 at 12:41 AM
HMAC300
  • 48,601 POSTS
check alternator it may be bad like the diode bridge inside.and check fusible link going to it. also check fuses under hood
Oct 14, 2015 at 2:57 AM
HARLEYGUY13126
Thanks will check and get back on results.
Oct 14, 2015 at 6:51 AM
