Battery light stays on while engine is switched off
263,000 MILES • 1.9L • 2WD • MANUAL
SYLVESTER1
My battery and odometer stays on while the engine is switched off and struggles to start after an hour.
Kindly advise if anyone has a solution.
Feb 6, 2019 at 3:51 AM
  • 110,251 POSTS
At some point, you have a short to power. The result is the lights stay on and the battery is draining. That is why it struggles to start.
With that in mind, here is a link that discusses a common cause of the battery getting weak after sitting. It explains how to find an electrical drain. Take a look through it. There are things that won't pertain to your problem, but as you continue through it, it discusses how to locate a short. Focus on step 3, the alternator.
https://www.2carpros.com/articles/car-battery-dead-overnight
Feb 6, 2019 at 12:14 PM
