If not, I would check the fuse # 4 gauges to see if it is good or not. Here is the alternator wiring diagrams so you can see how the system works and the fuse location as well. Check out the images (below). Please let us know what happens.
Image (Click to enlarge)
Nov 18, 2024 at 4:58 AM
ANNIMEDE44444
MEMBER
Thank you, we found out the problem, it was a frayed wire on the fusible link.
Nov 21, 2024 at 3:31 AM
✓Experienced Mechanic
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
