Battery light stays on?
2006 JEEP GRAND CHEROKEE
189,764 MILES
DAVID GREATHOUSE
Replaced the negative terminal and the battery yesterday and my battery light went off. This morning the car started and drove around the corner and my battery light came back on and won’t go off.
Aug 24, 2022 at 12:57 AM
  • 110,244 POSTS
We need to determine if the alternator is doing its job. All you need is either a multimeter or voltmeter to test it. Follow the directions in this link and let me know the results:
If that fails, then you will need to remove the alternator and have it bench tested. I say that because the voltage is regulated by the PCM and not an internal regulator. So, we can't use traditional testing.
Take care.
PS: Let me know what size engine it has so I can review the wiring schematics that are relevant.
Aug 24, 2022 at 12:37 PM
