Battery light on
18,000 MILES • V6
DJCOBRA
  • 5 POSTS
Put new alternator and light still turns on.
Aug 24, 2018 at 8:32 AM
Good evening.
You need to get a voltmeter to test both the battery voltage and the charging voltage.
You need 12.4 to 12.6 volts on the battery and the charging rate should be 14 to 14.5 volts.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Aug 24, 2018 at 11:36 AM
DJCOBRA
  • 5 POSTS
AutoZone checked battery and is fine.
Aug 24, 2018 at 11:42 AM
Okay, what were the results and what was the charge rate at the battery? They should have given you a print out.
If the light is on, it is from either a failed alternator or low battery voltage.
Aug 24, 2018 at 11:45 AM
DJCOBRA
  • 5 POSTS
I put in a new alternator, charge battery which he did a test and it was fine, but the light turns on and off. He said it is probably wiring or something electrical.
Aug 24, 2018 at 11:51 AM
Okay,
First, they are parts salesman not technicians. That is why I keep asking for the results.
Do you have a voltmeter? I would like to see the actual readings to give you help and not guess which is what they did at the parts store at your expense.
There are only two connections on the alternator. The one for the big wire from the battery and the one connector. Make sure they are clean and tight.
Aug 24, 2018 at 11:54 AM
DJCOBRA
  • 5 POSTS
Thank you it is late here, but tomorrow I will check and let you know.
Aug 24, 2018 at 12:02 PM
You are welcome. Sounds like a plan.
Aug 24, 2018 at 12:06 PM
DJCOBRA
  • 5 POSTS
Hi, I checked the alternator made sure it had no dust and wiring is good. Went for a ride the battery light did not go on until went shopping turn it off and when I was riding it turn on then off.
Aug 25, 2018 at 6:51 AM
Okay, and the voltage readings I asked for?
Aug 25, 2018 at 8:07 AM
