1996 Oldsmobile 88 Oil Pressure Light on
111,000 MILES • 6 CYL • FWD • AUTOMATIC
COLUMBIAN
  • 15 POSTS
When I start driving after 3-5 minutesOil Pressure light turns on and it flickers and eventually turns soilid. What is the problem? and how can I fix it? I appreciate your help.
Thank you
May 29, 2010 at 12:43 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
The first thing that you need to do is get the oil pressure checked with a mechanical gauge, if the pressure is with in spec, then replace the sender unit as it is problem faulty, start here.
mark (mhpautos)
May 29, 2010 at 12:55 AM
COLUMBIAN
  • 15 POSTS
How do I check the oil pressure for this car? and what is standard?
How do I replace sender unit?
May 29, 2010 at 1:14 AM
  • 31,937 POSTS
I will need to know the model and engine size.
Mark.
May 29, 2010 at 1:24 AM
COLUMBIAN
  • 15 POSTS
Oldsmobile Eighty Eight 3.8 L 6 CYL year 1996
May 29, 2010 at 1:31 AM
  • 31,937 POSTS
Normal oil pressure is 60 PSI @ 1850 RPM hot using 5W-30 or 10W-30 oil. the sender screws into the main oil gallery and this is where the pressure gauge will also attach, see pic for location depending on VIN of car.
https://images.2carpros.com/forum/automotive_pictures/61395_Vin_1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/61395_vin_K_3.jpg
mark
May 29, 2010 at 1:50 AM
