Battery light on
178,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
JOSH USHER
  • 8 POSTS
Battery is not being charged. Changed the alternator, connector plug that goes to the alternator. Checked continuity between PCM connector and the alternator plug, both tested good. Checked continuity between the bolt on the back of the alternator and the battery post, tested good. Not sure what to do here.. any help would be greatly appreciated.
Mar 20, 2019 at 11:09 AM
Good evening,
I attached a diagram for you to view.
Did you verify battery voltage to the red lead at the alternator?
Beyond that, you will need a scan tool to see if there is a duty cycle being sent to the alternator from the PCM. The PCM controls the voltage regulator turning it on and off according to load.
Mar 20, 2019 at 11:44 AM
JOSH USHER
  • 8 POSTS
With the key in the on position I am reading 5 volts going to the alternator at the red wire. I have a scan tool but it’s not sophisticated enough to get that far into it I don’t believe. The last thing on my list is the PCM but I don’t want to just order one, still hoping It can be resolved without having to buy one.
Mar 20, 2019 at 12:49 PM
Do you have battery voltage at the wire from the battery?
Mar 20, 2019 at 12:54 PM
JOSH USHER
  • 8 POSTS
The fusible link? Showing 12.3. Battery is partially drained at 12.3 right now.
Mar 20, 2019 at 1:00 PM
Okay, at this point you need a scan tool to see if the PCM is turning on the voltage regulator or not. It looks like the PCM but needs to be confirmed.
Mar 20, 2019 at 1:08 PM
JOSH USHER
  • 8 POSTS
That’s what I was thinking too. Wasn’t sure if anyone knew a trick I didn’t know, haha. Thanks for the help Roy.
Mar 20, 2019 at 1:11 PM
You are welcome.
Always glad to help.
Mar 20, 2019 at 1:14 PM
JOSH USHER
  • 8 POSTS
Is 5 volts sufficient to power on the alternator? I connected a temporary ground to see if it would come on but still wouldn’t.
Mar 21, 2019 at 1:18 AM
You need battery voltage to the heavy red wire.
The voltages from the PCM are pulse width modulated signals. That's why you need a scan tool to see those signals.
Did you ground the 5 volt wire? If you did, good chance you damaged the PCM.
Mar 21, 2019 at 2:38 AM
JOSH USHER
  • 8 POSTS
No, I grounded the grey field wire.
Mar 21, 2019 at 2:56 AM
JOSH USHER
  • 8 POSTS
I am taking the re-manufactured alternator back to the auto parts store. Made them test it three times before I left but going to test it again. Will post the results.
Mar 21, 2019 at 3:18 AM
Sounds good.
Mar 21, 2019 at 3:58 AM
JOSH USHER
  • 8 POSTS
Swapped out the re-manufactured for a new one and all works well.
Mar 21, 2019 at 5:22 AM
Good deal.
Mar 21, 2019 at 6:27 AM
