battery light on It needs a jump to start and then runs a bit rough?
232,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
It needs a jump to start and then runs a bit rough, not sure if related to the alternator. Once I check the battery voltage and charging voltage, ig I remove the alternator is there a way to check the connector behind it to see if am getting what I need to get? if so, what wires should have power and what need ground?
Aug 14, 2024 at 12:49 AM
BHAMDOC1973
  • 2,007 POSTS
I checked the charging, and it says 13.50. Battery is from 6/20.
Aug 14, 2024 at 7:19 AM
  • 55,694 POSTS
The battery is almost five years old so I would say it is bad. You can remove it and head to an auto parts store for testing or you can use this guide:
Here is a guide to help you test the alternator:
Here are the alternator wiring diagrams so you can see which wires go where. Check out the images (below). Let us know how it goes.
Aug 14, 2024 at 9:20 AM
BHAMDOC1973
  • 2,007 POSTS
Not solved yet. Changed the battery but i still have a battery light and the charging is over 13.
Aug 17, 2024 at 7:07 AM
  • 55,694 POSTS
It sounds like you need to do a battery monitor reset.
Here is a guide to help:
https://youtu.be/ETNv2S_idIU?si=BZPj8NUX1Wicemd-
Also, have you run the FCAN scan?
Aug 19, 2024 at 1:45 AM
