I have had a problem with my battery light turning on and off over the last month.
I have replaced my battery, my alternator, the serpentine belt, the belt tension-er, and now a mechanic is telling me that I need to have the fuel system cleaned and my spark plugs and wires replaced, otherwise the problem will not go away.
I am not a professional, but my father-in-law and I cannot seem to figure out why the spark plugs would not be a check engine problem. I have used Seafoam fuel system cleaner, and I will be using it again today, but it just does not make sense to me that the fuel system and spark plugs would trigger the battery light. I am worried that fixing those things will not fix the problem. Is there anything else that could be causing that problem? Thank you.
Aug 27, 2017 at 12:04 AM
