Battery light coming on?
3,747,284 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DANIELSHEA100
So, the battery light on my minivan was coming on when I stopped for a period and the dash lights were dimming and brightening. So, I had it tested, and they said that the battery was good, and the alternator checked out good, but the voltage was going up and down, so I went ahead and changed the alternator because they said that that is a sign of it going bad. Then I drove it and it came on again when I stopped for a period, what else do I need to check is there a fuse somewhere? Please help minivan is my fiancé and it is her work vehicle she cleans houses for a living.
Apr 4, 2023 at 1:21 AM
  • 55,694 POSTS
It sounds like one of the fusible links has one out or is weak, I would use this guide to check the connections and I have included the alternator wiring diagrams so you can see how the system works and which wires to test.
Apr 4, 2023 at 3:38 AM
DANIELSHEA100
I talked to a good friend of mine that works as a mechanic attic mechanic shop, and he said the easiest and cheapest way to fix it would be to run a 10-gauge wire straight from the alternator to the positive side of the battery. He said that will bypass the fusible links if one is bad. what do you think? I want a second opinion.
Apr 4, 2023 at 10:06 PM
  • 55,694 POSTS
Yep, that will work, also test the remaining fusible it is easy to do. Let me know what happens.
Apr 6, 2023 at 4:01 AM
DANIELSHEA100
I put the 10 gauge wire straight from the alternator to the positive side of the battery and that did not work battery light still came on.
Apr 6, 2023 at 4:05 AM
  • 55,694 POSTS
Did you check the fusible links? You may have a bad PCM or instrument cluster. I would do a CAN scan; you can get a CAN scanner (Controller Area Network) from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Here is one for about $99.00 if you need it:
https://amzn.to/3ZixY4v
Apr 8, 2023 at 6:09 AM
