battery light and anti lock come on
1997 MITSUBISHI MAGNA
247,000 MILES
TRIXELLLL
hi
while i was driving last night the battery and anti lock light come on and stayed on. after about 15 mins when i got off the motorway and braked the anti lock light went off and back on when i accelorated. this morning my car wont start at all there isnt a noise or anything when i try kick it over, any ideas???
Jun 6, 2013 at 8:43 AM
CARADIODOC
  • 34,380 POSTS
Most likely suspect is the generator. If it stops charging the battery the red warning light will turn on to tell you. You be able to drive about a half hour before the battery runs down. Charge the battery so you can start the engine and drive to your mechanic. Have him test the charging system.
The anti-lock brake light will turn on in response to the low system voltage. That will prevent it from working correctly so the computer turns the system off and turns the yellow light on to tell you.
Jun 6, 2013 at 8:52 AM
