Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Delta 88
Warning Lights
Battery Light
Battery light remains on after replacing alternator and battery
1998 OLDSMOBILE DELTA 88
169,000 MILES • 3.8L • V6 • AUTOMATIC
SWEETJESUS
MEMBER
1 POST
Replaced both battery and alternator and battery light still on. What could be wrong? Is it a fuse, pulley?
Nov 5, 2020 at 12:27 PM
Experienced Mechanic
Good morning,
I attached a wiring diagram for you to view. Check the 2 fuses that I circled for power on both sides.
If they are good, we need to test for voltage to the alternator. You will need a voltmeter for the test. The ECM controls the alternator but before we go there, we need to do these checks.
Image (Click to enlarge)
Nov 5, 2020 at 8:56 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
