Battery light stays on
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOHNIE TAYLOR
  • 6 POSTS
My car is charging and battery is okay, but battery light stays on.
Jun 27, 2018 at 9:02 AM
HARRY P
  • 2,292 POSTS
Your alternator may be overcharging or otherwise performing improperly. I would take it to the nearest auto parts shop and have it tested. They will do it for free and get accurate readings so you can know what is going on. Then report their findings back here and we will go from there.
Or you can try doing the test yourself. Here is a guide on how to do it yourself: https://www.2carpros.com/articles/how-to-check-a-car-alternator
Good luck and keep us posted.
Jun 27, 2018 at 1:28 PM
JOHNIE TAYLOR
  • 6 POSTS
I had the alternator tested and the battery to both okay. I said I knew very little about fixing cars but I am not a mechanic, but know a lot about car repair.
Jun 28, 2018 at 12:48 AM
HARRY P
  • 2,292 POSTS
This is the junction box located next to the battery. Check fuse #6. It is for the alternator. If blown, your alternator will show as charging, but not actually be charging, which will trigger that light.
Jun 28, 2018 at 11:15 PM
JOHNIE TAYLOR
  • 6 POSTS
I checked number six fuse it is not blown it is okay. there is something I forgot to mention when I sent the first question in the light go's out sometimes usually of a morning when you first start the car but soon as you start to move it comes back on but sometime it does not come on at all, but usually it does. I hope this helps you to figure it out. Sorry I did not mention this before. I just did not think to about it, sorry.
Jun 30, 2018 at 10:54 AM
HARRY P
  • 2,292 POSTS
I was doing some reading and found out that with this car, whenever the battery light is on, it should be setting a trouble code. If you do not have a scanner, take it to the nearest AutoZone or other auto parts store and get it scanned. report back here with the codes, and I can look them up and see exactly where to go from there.
Jun 30, 2018 at 9:39 PM
JOHNIE TAYLOR
  • 6 POSTS
I took the car to AutoZone to have it scanned the guy said the scanner would not show any codes if the check engine light was not on. The check engine light is not on so he would not scan it. He did check the alternator and battery again. Alternator putting out 12 volts, battery is good. Yes the battery light was on when he tested it.
Jul 2, 2018 at 4:51 AM
HARRY P
  • 2,292 POSTS
How do your battery terminals look? Dirty/corroded cables and terminals can cause a battery light to come on. Check this guide out: https://www.2carpros.com/articles/everything-goes-dead-when-engine-is-cranked
Jul 2, 2018 at 8:40 PM
JOHNIE TAYLOR
  • 6 POSTS
No, my battery terminals are not dirty or corroded cables look good too. I took the car to Advance Auto Parts they ran a scan on it but it did not show any codes.
Jul 7, 2018 at 5:07 AM
STEVE W.
  • 15,423 POSTS
Okay, you say it sometimes goes off but not always, that sounds like a loose connection, either in the wiring or a bad solder joint on the actual board. Scanning to get codes for the charging system takes a bit better scanner than most of the "free scan" places use. They can do most engine/power-train codes but only when it is an active code.
Do you have a voltmeter you can test with? I would like to know the battery voltage at rest engine off. Then the same voltage engine running and engine at 2,000 rpm. All measured at the battery terminals. You should see around 12.6 key off, then 13+ at idle and above.
Check the wiring harness from the alternator back into the main harness, I have seen a couple Escapes where the wiring had melted a bit and the wires were shorting and it would randomly cause a charging issue.
Jul 9, 2018 at 8:50 AM
