Battery light stays on
150,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
HEATH.SHARP
The battery is fine and the alternator is charging but the light is staying on?
Feb 10, 2020 at 12:15 AM
JOETECHPRO
  • 705 POSTS
Hey HEATH.SHARP,
What is the battery voltage with the engine running at idle?
Regards, Joe
Feb 10, 2020 at 12:33 AM
Good morning,
What is the voltage at the battery with the engine running?
The voltage is critical. Also, check for any AC voltage as well. It could still be a bad alternator from a bad diode.
Also, verify the fuse I circled for power on both sides. The ECM controls turning on the alternator depending on the load of the car.
Feb 10, 2020 at 12:39 AM
HEATH.SHARP
hey, the voltage when running is 13.4.
Feb 10, 2020 at 7:45 AM
HEATH.SHARP
Also she had an alternator put in back around October.
Feb 10, 2020 at 7:48 AM
It is too low. It should be 14 to 14.5 volts.
Feb 10, 2020 at 8:07 AM
Try turning on the headlights and see if the voltage drops or raises.
Feb 10, 2020 at 10:19 AM
