battery keeps dieying
130 MILES
TINAP7769
  • 5 POSTS
checked alternater and belts both were good changed battery post also got new battery. i get a jump starts right up then the clock light starts going dim then car starts to stall out.
Apr 19, 2013 at 10:34 AM
sounds like the alternator has failed. what is the voltage at the battery???
Apr 19, 2013 at 11:39 AM
TINAP7769
  • 5 POSTS
I have checked the alternater at the autozone they said it was fine then i checked the belt and put new terminals plus I just got a newer battery about two weeks ago because of the dieing out.
Apr 19, 2013 at 12:28 PM
ok, once again, what is the voltage at the battery with the engine running??
roy
Apr 19, 2013 at 6:57 PM
TINAP7769
  • 5 POSTS
it was 14 drove 10 miles then clock light went dim now voltage is at 12
Apr 23, 2013 at 10:17 AM
you have an alternator issue.
Apr 23, 2013 at 10:56 AM
