I did a test with my digital ohm meter between the battery post and the terminal connector on the negative side. The problem is the hood light comes on still. When I probe just the negative side to test it goes from 9.00 to 14.00 when the light comes on. Also, when I pull the fuse that says rdo amp it drops to 09. Any thoughts on this?
Thanks, Scott F
Thanks, Scott F
Aug 8, 2018 at 3:36 PM
