Battery fuse/fuses fuse box
150,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
NATE CROSLIN
  • 8 POSTS
Next to the battery is a cluster of four fuses. One is battery and the other three are ignition, power windows, sunroof.
The plastic fuse holder for the battery fuse cracked and is shorted out. I can not find a replacement so I need to find a solution.
So my questions are-
1) What is the amperage of the battery fuse?
2) Is there any place to buy a new fuse and fuse holder?
Oct 1, 2018 at 6:49 AM
  • 55,691 POSTS
Hi Nate,
The battery fuse is usually 40 amp you will not find an exact replacement you will need to wire in an aftermarket fuse holder which you can get at AutoZone.
Cheers, Ken
Oct 3, 2018 at 5:21 AM
  • 55,691 POSTS
Hi Nate,
The battery fuse is usually 40 amp you won't find an exact replacement you will need to wire in an aftermarket fuse holder which you can get at autozone.
Cheers, Ken
NATE CROSLIN
  • 8 POSTS
Thank you Ken that helps a lot. Nate
Oct 3, 2018 at 7:11 AM
  • 55,691 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Oct 4, 2018 at 3:39 AM
