Battery draining?
130,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MHINSATX
Battery keeps draining. Replaced battery, serpentine belt and alternator but issue remains. Using a voltmeter on 20-amp setting, the reading went from 22mA to 1or 2 mA after 90 minutes or so of being turned off. When I first cold start the Tribute, voltmeter shows 13.2 to 13.9 without a load. With load applied, it drops below 13.0 and doesn't go back up. I haven't physically checked the cabling. I also installed an aftermarket radio.
Sep 11, 2023 at 7:33 AM
  • 55,691 POSTS
1 or 2 mA after 90 minutes is acceptable, so I am not sure if you have a drain, (mA milliamps, correct?) is the battery dead after a few days or overnight? This guide may help:
https://www.2carpros.com/articles/car-battery-dead-overnight
Please go over this guide and get back to us.
Sep 12, 2023 at 4:19 AM
MHINSATX
Hello, I figured out what my problem was. I was not getting a good ground on my engine. Once I rectified this issue, my battery has been getting and staying charged. Thank you for your assistance.
MHinSATX
Sep 14, 2023 at 6:55 AM
  • 55,691 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Sep 15, 2023 at 3:19 AM
