Battery drains overnight from 100% to 0%?
136,189 MILES • 5.3L • V8 • 4WD • AUTOMATIC
SMALLS367
Got this suburban in December 2024. i have had drained batteries almost twice a week. I replaced the battery and then had the new one tested; it passed. Then I had the alternator tested, and it also passed. You can see the battery gauge on the dash, and it constantly charges between 13 to 15 volts. I found a drain from the radio and pulled the fuse; it seemed to help but did not cure the issue. Live data from driving and monitoring says the system is at 14.2 volts. I have taken to a local shop that specializes in electrical issues, and they said the radio sounds right, but they could not replicate it. Is there something i am missing? Please help.
Mar 18, 2025 at 7:50 PM
BORIS K
  • 836 POSTS
Your battery drain is usually caused by a parasitic draw, meaning something is staying on when the vehicle is switched off.
A link:
https://www.2carpros.com/articles/car-battery-dead-overnight
Video links:
https://youtu.be/z5F7WpgjaRs?si=cGcEqDdEK2IrsX0V
and
https://youtu.be/RkzSub1dtNQ?si=4a2eJJ_YJhYN-rzf
How to use a voltmeter:
Hope this helps.
Cheers, Boris
Mar 18, 2025 at 9:51 PM
