Battery drains over night?
168,000 MILES • 6 CYL • AUTOMATIC
SIMPLYMERC
Hi, every morning I have to jump my car to start. i couldn't figure out what the issue was until i saw my cars fog lights and rear lights would blink intermittently, sometimes when i turn the radio on it gets stuck on the "Mercedes Benz" logo and then it will turn on by itself, the inner flash lights won't turn on for a while until the car has run for some times, the radio also gives static noise intermittently. i think it's the alarm sign module but i could be wrong.
Thanks in advance.
Jan 14, 2023 at 12:11 PM
  • 55,691 POSTS
It sounds like you may have a weak battery, I would follow this guide to load test the battery
If the voltage of the battery is low, it will cause the systems to malfunction. If the battery is new or tests good, I have seen the battery in the alarm module leak and cause all kinds of weird problems, check out this video of the job being done in a similar merc:
https://youtu.be/3S0Ns3O3ULA
I have also seen the front or rear SAM module go out causing strange problems as well but to be sure we should do a CAN scan which is easy, you can get a CAN scanner (Controller Area Network) from Amazon from about $32.00 here is a video to show you how.
https://youtu.be/u-4syLc-ifQ
and
Amazon CAN scanner Link.
https://amzn.to/3G7mpFP
Check out the images (below). Please let us know what you find. We are interested to see what it is.
Jan 15, 2023 at 3:10 AM
