Battery drain is slightly after trying to crank over.
Apr 19, 2018 at 8:46 PM
HARRY P
✓Experienced Mechanic
I would suspect that the battery is bad. If you can, take it out of the car and go to the nearest auto parts shop. They will test it for you for free. Let us know what happens.
Apr 19, 2018 at 9:07 PM
PATENTED_REPAIR_PRO
They should charge the battery fully before load testing it, so unless you want to wait two hours while they charge it, if you have a charger, charge it yourself first before you take it to be load tested, or just purchase a load tester from Harbor Freight or Walmart for $22.00. https://www.harborfreight.com/100-amp-612v-battery-load-tester-61747.html
or https://goo.gl/K3YgKc
Apr 19, 2018 at 11:09 PM
HARRY P
Or you can just drop it off with them and go back later for results.
