Battery draining as soon as i crank
200,000 MILES • 0.8L • V8 • 2WD • MANUAL
HALIJ1206D
My SUV has a drain in the battery. I have to jump it off every time I stop. As of this morning I now cannot get the battery to even charge enough to drive but a small ways.
Jan 31, 2019 at 6:21 PM
Good morning,
It sounds like you have a bad battery. You need to have it charged to 12.6 volts, not jumped, and then load test it.
I also would check the charging system as that is the job of the alternator to maintain the battery charge.
Jan 31, 2019 at 6:52 PM
