Battery drains when not running?
162,000 MILES • 3.3L • 6 CYL • 2WD
BUYRITEAUTO21
  • 35 POSTS
I have the vehicle listed XLE. It has a lot of features upgraded from the base model like navigation, DVD player, heated seats, remote start and power lift gate. When the van sits for several hours, sometimes the battery is drained. Are these extra features draining the battery when not running?
Thank you
Jul 24, 2023 at 11:55 AM
  • 55,721 POSTS
Yes, they could be if they are not wired up correctly, please follow this guide to get us started on finding out the problem, if the power leads for the accessories are easy to get at, I would start by removing them.
https://www.2carpros.com/articles/car-battery-dead-overnight
Please go over this guide and get back to us.
Jul 25, 2023 at 12:11 PM
BUYRITEAUTO21
  • 35 POSTS
Where would I find the power leads for the accessories? I’m not sure if this could contribute to the battery dying but I also have an anti-theft red light that always blinks when the vehicle is off, and the power sliding doors do not work. Also, would simply removing the fuses for any of the accessories reduce battery drain?
Thank you
Jul 25, 2023 at 11:28 PM
  • 55,721 POSTS
How old is the battery it could be bad which causes a drain like symptom. If you don't know please charge the battery completely and then do a battery load test, this guide can help:
https://www.2carpros.com/articles/how-to-charge-your-car-battery
and
This is how to change the battery out in case you need it. Here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Jul 27, 2023 at 8:17 AM
