Battery drain
155 MILES • 6.0L • V12 • 2WD • AUTOMATIC
RAMZITH1
  • 79 POSTS
A new battery installed, but it drains quickly. The car starts normal after jump but next day again drain.
Sep 27, 2018 at 6:43 AM
HARRY P
  • 2,292 POSTS
Sounds like there is a parasitic drain on the system. There is a test that anyone can do for an electrical short. All you need is a multi-meter ($15.00 to $20.00 or so at AutoZone). Disconnect one of the battery cables from the battery. Touch the disconnected cable to the other cable so any residual energy in the system is grounded out. Take your multi-meter, turn it on, and set to 20 volts DC. Take one lead and connect it to the newly disconnected battery cable, and connect the other lead to the battery post that the disconnected cable came from. You should see some sort of reading. Now start unplugging fuses, one at a time, until you see a significant drop in the meters reading. You have now identified the circuit..
This is the multimeter that I have: http://www.sears.com/craftsman-multimeter-digital-with-8-functions-and-20/p-03482141000P?plpSellerId=Sears&prdNo=1&blockNo=1&blockType=G1
Another way of testing would be to remove two different fuses every day and see if the car starts the next day. If so, then one of those systems is causing the draw. Narrow it down by repeating that test, except only remove one fuse and leave the other in place. This method can take days or weeks to go through, but you will not have to buy any special tools.
Are there any aftermarket electronics on or in the car? Perhaps a stereo system or maybe a beefed up security system? Or have any electrical systems had service performed on them recently? That is where I would start, personally.
Let us know which fuse it was and I will personally look up what is on that circuit.
Sep 27, 2018 at 7:02 AM
RAMZITH1
  • 79 POSTS
Dear,
Recently I replaced the old stereo that has Japanese language with a newer one with screen but still original as you can see from attached pictures, should disconnect it and see if the battery drain again.
Before I replaced the stereo there was no battery drain.
Thanks
Sep 27, 2018 at 8:56 AM
HARRY P
  • 2,292 POSTS
If you did not have to cut and splice any wires and the radio works correctly then I would not focus too much on it. Run the test using the multi-meter if you can and you'll find that problem circuit in fifteen minutes.
Sep 27, 2018 at 10:05 AM
RAMZITH1
  • 79 POSTS
Will do the test and let you know.
Sep 27, 2018 at 3:26 PM
  • 55,554 POSTS
These cars had a problem not going into sleep mode, it sounds the the SAM controls are staying live. You will need to take the car to the dealer to have them read the body controls to see whats staying on and why. They are the only ones that have the software to do the job.
Sep 30, 2018 at 5:27 AM
RAMZITH1
  • 79 POSTS
Well, I have replaced the battery again with new MB battery, and I left it now two days without starting it, now I start the car and it starts normal. I checked the voltage reading shown in the picture attached, will see two more days and let you know.
Thanks
Sep 30, 2018 at 6:09 AM
  • 55,554 POSTS
Maybe the first battery was bad and the car will be okay. Time will tell please let us know.
Oct 1, 2018 at 1:44 AM
RAMZITH1
  • 79 POSTS
I left the car since last night until today 1700 local time and started it, again it starts normal.
Well, I will keep you updated.
Thanks
Ramzi
Oct 1, 2018 at 2:32 AM
HARRY P
  • 2,292 POSTS
Wow that is odd! I suppose anything is possible. I guess this is a reminder that just because a part is new does not necessarily mean it is good.
Oct 2, 2018 at 9:53 PM
RAMZITH1
  • 79 POSTS
Yes, it is odd. I do hear the alarm sounds weak while it is parked and not running then disappear, tried to run the engine but the battery need to be charged again.
Oct 3, 2018 at 12:09 AM
  • 55,554 POSTS
There is a separate battery for the alarm system that lives in the horn. Here is a video to help see what I am talking about. This can be causing your problems.
https://youtu.be/3S0Ns3O3ULA
Cheers, Ken
Oct 3, 2018 at 4:49 AM
RAMZITH1
  • 79 POSTS
Thanks Ken, will try to replace that part and see what happen, I think it is the problem.
Oct 3, 2018 at 4:00 PM
  • 55,554 POSTS
Yep, let us know.
Oct 4, 2018 at 4:22 AM
RAMZITH1
  • 79 POSTS
Dear Ken,
I know it has been a while to write back to you, well, the alarm siren been changed to my car and the issue of drain battery solved.
Thanks for your help I really appreciate it.
We will be in contact soon.
Best regards,
Ramzi
Nov 30, 2018 at 9:07 PM
  • 55,554 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Dec 1, 2018 at 3:33 AM
HARRY P
  • 2,292 POSTS
That is great to hear! Please do come back in the future.
Dec 1, 2018 at 12:18 PM
RAMZITH1
  • 79 POSTS
Thanks Mr. Heyman and Ken for your help I really appreciate it.
Dec 2, 2018 at 7:38 PM
HARRY P
  • 2,292 POSTS
No problem. Come back anytime and send your friends too.
Dec 2, 2018 at 7:51 PM
