battery discharges
63,650 MILES • 0.5L • V8 • 2WD • AUTOMATIC
JOHN 55
This is a 1979 dodge flair motorhome with 63,650 original miles on it. I replaced the alternator; it runs idling until it discharges battery. i didn't check fusible link at battery unplugged shuts off immediately after. What's the problem?
May 4, 2022 at 7:43 AM
Good morning,
I don't know if you know this; removing the battery cable while the engine is running never tells you anything and can damage the modules from a voltage surge.
Use a test light or voltmeter and verify the power to the back of the alternator. The engine should die when the battery is disconnected.
I attached a guide for you on the charging system. It gives you good information on testing.
https://www.2carpros.com/articles/car-battery-dead-overnight
With the engine running, you should have 14 to 14.5 volts. Please confirm that and let me know.
May 5, 2022 at 12:42 AM
