not started everyday the battery drains
260,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
SHANED88
If the truck is not started everyday the battery drains. I tested everything even pulled the fuses out, but nothing is helping.
Oct 1, 2018 at 7:39 PM
Did you have the battery load tested? If the battery is shorted internally, it will drain itself.Also, did you do a parasitic draw test? Use an amp meter and remove the negative cable. Install the amp meter leads to the battery and the cable. Let it sit for one hour and then check the reading. It should have only 50-75 milliamps of draw.
https://www.2carpros.com/articles/car-battery-dead-overnight
May 13, 2021 at 11:37 AM
SHANED88
I let it sit a for a while and then I heard the fuel pump running so I replaced the fuel pump relay all fixed.
