My battery died after being on for two hours and now my whole dash board wont light up. I already checked both fuse boxes.
Nov 29, 2016 at 9:00 AM
SATURNTECH9
✓Experienced Mechanic
So it was running when all this happened?
Nov 29, 2016 at 10:30 AM
MPRINGLE2O15
MEMBER
Well it was on so I could charge my phone.
Nov 29, 2016 at 10:38 AM
SATURNTECH9
If it was not running you probably killed the battery. you can try to jump start it and let it run for twenty minutes or so and have to have the battery tested.
Nov 29, 2016 at 10:55 AM
MPRINGLE2O15
MEMBER
Yes car runs fine, but now the whole dashboard is dark will not light up.
Nov 29, 2016 at 11:59 AM
SATURNTECH9
Did you jump start it?
Nov 29, 2016 at 12:28 PM
SATURNTECH9
So the warning lights come on when you turn the key on before you start it? Do your parking/running lights work?
Nov 29, 2016 at 12:34 PM
MPRINGLE2O15
MEMBER
No and the low gas sign comes on but is a full tank.
Nov 29, 2016 at 7:34 PM
SATURNTECH9
Did you jump start the car to get it started?
Nov 29, 2016 at 10:33 PM
SATURNTECH9
Also, does your gas gauge read the fuel level is low as well ?
Nov 29, 2016 at 11:33 PM
MPRINGLE2O15
MEMBER
Yes car runs fine, just dash wont light up and I checked all fuses and they are fine.
Nov 30, 2016 at 2:21 AM
SATURNTECH9
Is the gas gauge reading a lower level then it should now? Did you jump start the car to get it going again? You need to please answer the questions I keep asking that are going unanswered or it is impossible to try to help you.
Nov 30, 2016 at 4:49 AM
MPRINGLE2O15
MEMBER
The gas keeps saying it's low but it's not. The car runs fine meaning yes it has started and we can drive it
Nov 30, 2016 at 9:31 AM
SATURNTECH9
Sounds like the body control module could have failed with the gas gauge acting like that suddenly since the battery went dead.To restart the car after you said it wouldn't start and the battery died did you jump start the car to get it started again?Also does your parking/running lights work?there on the same circuit as your dash lights?
Nov 30, 2016 at 11:07 AM
CJ MEDEVAC
Reckon
Now that the battery is charged up,
Snatching the negative cable off of the battery for a few minutes, then reconnecting it, might let the computer stuff recognize full voltage. Seeuns how at the moment it may be still hung up on the low voltage tragedy?
Just a thought,
Keep us posted
The Medic
Images (Click to enlarge)
Nov 30, 2016 at 11:44 AM
SATURNTECH9
A European car sure but domestic cars don't usually do that.
Nov 30, 2016 at 11:47 AM
MPRINGLE2O15
MEMBER
We did jump start it. It's runs and no we cannot see gears change. The only thing that is lit up is the little light to tell us we are low on gas . Which we are not
Nov 30, 2016 at 1:20 PM
SATURNTECH9
When you turn on your headlights the rear lights come on not the brake lights also the front parking lights do those work?
Nov 30, 2016 at 1:23 PM
MPRINGLE2O15
MEMBER
I have not tried but will later. Thank you
Dec 3, 2016 at 12:36 AM
SATURNTECH9
Sounds like it the body control module could have went bad.Keep me posted.
