Where is the Battery Circuit Fuse located?
150,000 MILES • 2.7L • 6 CYL • 4WD • AUTOMATIC
KERRIANNETA
It is getting older and is having some problems, but the main problem we are up against now, as I've been told, is that I need to replace the Battery Circuit Fuse. I went ahead and purchased a new one. The part is Dorman Part number 926-012 (here is a link to the part I purchased https://www.dormanproducts.com/p-83514-926-012.aspx?origin=keyword). My new problem is I don't know where to install it! I cannot for the life of me find where the old one is located (if it is even there), and where I'm supposed to put it. Can anyone please help? I've been working on this for almost 2 months now and it's driving me completely nuts. Thank you so much!
Feb 18, 2025 at 7:44 PM
AL514
  • 5,696 POSTS
Hello, according the your part link, I do not see a 2005 Dodge Stratus 2.7Liter, only the 3.0liter engine, usually a fuse like this would bolt right to the battery terminal, especially being a 120Amp fuse. Do you have the correct engine size listed? And what are the symptoms you are experiencing?
Feb 19, 2025 at 2:35 AM
AL514
  • 5,696 POSTS
In service information, for 2005, they have listed a Dodge Stratus (Coupe) as having a 2.4liter engine or a 3.0liter, for the Dodge Stratus (Sedan) they have listed a 2.4liter and a 2.7liter engine only. So that might be the difference and issue with that part number.
Feb 19, 2025 at 2:38 AM
