Battery charging
59,413 MILES
KGETZ
  • 104 POSTS
I just put a battery charger on my van battery to give it a full charge since I mostly do more around town driving then long-distance driving. When it completed, I let it sit to let the surface charge wear off, and when I checked it with my volt meter. It is only sitting at 12.3 instead of 12.5 or 6. The charger I got recommends using it on 12 volts batteries with rated capacities 22-75 Ah. The battery in the van says its Ah is 80. Would this be causing it?
Sep 30, 2018 at 9:17 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
I would suggest having the battery load tested. It might not be holding a charge or failing under load. Your local auto parts stores (AutoZone, O'Reilly's, Pep Boys)will test for free. I have attached a tutorial showing what is involved. Hope this helps and thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/how-to-charge-your-car-battery
Sep 30, 2018 at 9:43 AM
KGETZ
  • 104 POSTS
I just went out about fifteen minutes ago and it was up to 12.49.
Sep 30, 2018 at 9:44 AM
DANNY L
  • 5,648 POSTS
Hello again.
What is the alternator output with engine running?
Danny-
Sep 30, 2018 at 10:22 AM
KGETZ
  • 104 POSTS
Have not checked it. I do know it is a 160 amp alternator.
Sep 30, 2018 at 10:24 AM
DANNY L
  • 5,648 POSTS
Hello again.
Using a voltmeter I would suggest checking the alternator output with engine running to determine if the alternator is performing within specification. I have attached a tutorial showing how to test. Hope this helps and thanks for using 2CarPros.
Danny-
Sep 30, 2018 at 10:33 AM
KGETZ
  • 104 POSTS
What should the reading be when I run the test? I will have to do it during the day. I am in Pennsylvania, it is 8:30 and the sun is completely down.
Sep 30, 2018 at 10:38 AM
KGETZ
  • 104 POSTS
The alternator put-out bounces between 13.82 and 13.84.
Sep 30, 2018 at 11:18 AM
