Battery change
67,000 MILES
RANDY85
Battery kept draining but would crank right up once it was jumped. So I removed it to get charged and it was fully charged but once I put it back in the car has no power at all and the key is stuck in the ignition.
Nov 29, 2018 at 4:44 AM
Good afternoon,
Recheck you connections and make sure they are clean and tight.
Do you have a voltmeter to check the voltage? It needs to read 12.6 volts.
Nov 29, 2018 at 5:02 AM
RANDY85
No.
Nov 29, 2018 at 11:57 PM
You can get a cheap one at a parts store for the checks.
Nov 29, 2018 at 11:59 PM
RANDY85
I hooked jumper cables up to it and got sparks, so that should mean the battery is okay, right?
Nov 30, 2018 at 12:50 AM
No it does not. They need to be tested with a meter.
Nov 30, 2018 at 1:00 AM
RANDY85
Okay, thanks.
Nov 30, 2018 at 1:38 AM
You are welcome.
We are here to help.
Nov 30, 2018 at 3:00 AM
