Battery cables
150,000 MILES
SUE0800
I need to replace the positive battey cable on my Camery. And I need to get to the place where it is hooked on to so I can pull the old cable. It is hard to get to. I would like a few tips on how to get to the area easily. Thank you.
May 17, 2013 at 8:51 AM
you listed no motor size....
May 17, 2013 at 9:31 AM
SUE0800
It is a 2.2l efi dohc.
May 17, 2013 at 11:57 AM
the end is at the starter motor on the drivers side of the motor. it is under the 12 mm nut on the solenoid.
May 18, 2013 at 12:10 AM
SUE0800
I have traced that out. But how would I be able to get to it. Ther is not alot of room to put a socket. Thank you for all your help. If you can give me the easiest way to get to it I will be very happy. Thank you again.
May 18, 2013 at 1:43 AM
