CHARLES TURNER
every morn battery is dead and i haveto jump it i disconected the battery win it was running to check alternater it countenued to run so i think alternater is good please help
Apr 24, 2013 at 10:48 PM
JDL
  • 16,098 POSTS
Have you had the battery tested? Also, check for a battery drain. Generally the drain shouldn't be over 50 ma/.050 amps. If drain is too much, pull/replace fuses one at a time, when you pull the fuse on the problem circuit, the excess drain goes away. Check for lites that may be on, interior--under the hood, whereever. The best time to check for that is in the dark.
Apr 25, 2013 at 1:12 AM
